A problem was encountered when running a shell command. The system is not functioning as expected. The problem may be related to the failure to allocate an internal system resource. The arguments for this event are: - shellCommand: Shows the shell command which failed to execute. - errorMessage: The reason for the command failure.
The exact remedy is dependent on the particular situation; but the problem may be resolved by retrying the operation when the resource becomes available.
Error
Failed to execute shell command %shellCommand%: %errorMessage%.
| Name | Type |
| shellCommand | String |
| errorMessage | String |
